Yeah the previous owner sprayed the whole car with primer to cover up all the rust on the car. Will the rust continue to eat away at the metal with the fiberglass over it?motoman399 wrote:what they did didnt get rid of the rust. just covered it up. i used to work in a body shop and there is a few ways you can do it.
the easiest way is to sandblast the rust out till its gone and then use a pointy hammer and tap the edges inward. then fill that with fiberglass bondo. then sand and bondo then sand then glaze. or you can cut and weld.
