simmode1 »
https://forums.nicoclub.com/simmode1-u73804.html
Sun Oct 25, 2009 8:34 am
It's all a function of how low you are. Even a 1/4 of an inch is enough to rub if you're slammed. But if you're just dying to rip out your fender lining, knock yourself out.
Edit: I just read your other thread. Apparently, you aren't even that low. Another solution might be to spray paint your fender lining with a bright color so that you can see exactly where it's rubbing if you're not sure where. And then pound that spot out of the way with a hammer or rubber mallet. Then, of course, re-piant the lining black again. Less work than raising the car or pulling the lining out and cheaper than buying spacers....
Modified by simmode1 at 11:57 AM 10/25/2009
