fender rolling question with pics
93Z
Car: 1993 300zx 2+2
I just wanted to post some pics of my back wheels and see if fender rolling is gonna be enough or if im gonna have to add some negative camber in there too. Thanks for any help.
ArticDragon192
Car: 91 Z32 2+2
Fender rolling only flattens the lip. will definitely need some camber and possibly a pull.
93Z
Car: 1993 300zx 2+2
So do I just need rear adjustable UCA's to adjust the camber? And how much faster is my tread gonna wear
ArticDragon192
Car: 91 Z32 2+2
If your toe is in check it shouldn't wear out that bad. You'll still be able to flip the tires and have usable tread again when needed. Its not like you'll wear them out like crazy. But you'll need more than just camber to fit those tires.
300ZXttZMAN
93Z,
To add to what Edgar said, just so you know camber has very little to do with tire wear... The toe being out of wack is what really starts to wear down your tires..
Think about a snow plow going down the street. Snow plows are at an angle so that they can push the snow out of the street meanwhile the vehicle pushing the plow is going straight. Well thats what your tires are doing. Since the tires are pointed at an angle but the car is going straight its creating alot of rolling resistance.
Make sense?
If you still don't understand check out this link:
http://www.ozebiz.com.au/racetech/theory/align.html
I didn't actually read that article but it looks like it would answer any more questions you may have. :bigthumb:
If not just post in this thread.
Shoey2
Car: 1990 300ZX Fairlady Z Twin Turbo
+1 on the negative camber and a roll...should look nice.
93Z
Car: 1993 300zx 2+2
thanks guys. im gonna work on it this weekend. i bought a heat gun and stuff. ill post pics when its all said and done. i bought adjustable camber arms. How do you adjust the camber on them? i bought these http://www.conceptzperformance.com/Cart ... 254.90.132
