Lev_96_240sx wrote:1 inch = 25.4mm, Are you using spacers on those wheels?
NO spacers. Rims are Sport Max 502 model Could it be broken bushing that are cousing this??sr_240sx wrote:I have 255 tires on and they pop out almost 1" from the fender. That is way I made the thread. Tires are Potenza the rim has 3" lip. Could it be broken bushings???
Modified by sr_240sx at 10:35 AM 1/11/2010
Ok yes indeed the 4 bushings from the sub frame are broken a couple from the part the bars atach on the hub area. Suspension Tokico shocks and Eibach Sport line.Lev_96_240sx wrote:Your car would ride very strangely if you had a broken bushing. Bushings don't really effect how the car is aligned, they are part of the control arm buffering the contact points so you don't get metal on metal friction. Your car would pop lie crazy with bad bushings.
What is your suspension setup? I think this is the biggest question at this point.
AH! I didn't even thing about that. He said he didn't have spacers tho so...simmode1 wrote:This is crazy. You really should figure why your wheels aren't fitting right before you try to cover up the problem with fender flares. You don't have some wonky, cobbled together 5 lug conversion, do you?
Do the wheels stick out 1 inch on both sides? If so it can't be just the subframe. Even if the subframe had shifted, it would only stick out on one side.sr_240sx wrote:I have OEM 4 lug hub from 21 years ago!!!! I think that has to be the subframe bushings I pops from one side
Lev_96_240sx wrote:an 18x9.5 +35 wheel should not need overfenders.
An 18x9.5+35 275/35 should only poke out 9mm more than this... which is barely even noticeable to this point. A fender roll is all that should be required. Maybe a slight pull if you're slamming it. Of course, the more negative camber you dial in, the less fender pulling you'll need to do.Broadfield wrote:5 Lug ConversionStoptech 13" Brakes Front (Only 18's or bigger will clear these)Z32 Brakes RearWedsSports TC-005's 18x8.5 +32 245/4018x10 +44 275/35Cusco CoiloversRolled Quarters
