float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Dec 05, 2006 8:24 pm
w00t! I'm cooler than I thought! And now to expound on my personal theory of why...
I would guess that when they originally cast it, they wanted as much coolant flow as possilbe, hence the numerous, large ports. The problem was that the coolant flow wasn't very well directed. The coolant is going to take the path of least resistance, so the coolant would pass out of the pump and into the cooling area of the first cylnder, because it had an easy path up into the head and then out to the radiator, it took it. The remaining cylnders would get some flow, but not nearly as much as the first.
By redesigning the HG to force the coolant to flow past all of the cylnders (for the most part) and THEN up into the head, the cooling was increased.
But now your next question is, "OK smart guy, why didn't they make the ports in the head match the new gasket?" Well I have a theory for that too. I believe the idea behind the larger-than-needed ports was to increase the contact area of the coolant around the combustion chamber.
So there ya go, that's my theory anyway.
