T-rev »
https://forums.nicoclub.com/t-rev-u68340.html
Wed Feb 20, 2008 4:35 pm
you definatly have an issue with too much fuel, especialy if you can smell it at the tail pipe, or elbow. If you smell fuel, it aint right, trust your nose.
Just a thought, what if its not a fuel prblem? but what if you have a weak coil pack. Its not firing at low rpms, but comes to life at higher rpms. You're sure you're not running on 3 cyl?
I had the opposite problem once where it would cut out at high rpms, this was after a mechanic told me coil packs are either working or they're not, no inbetween. Yes they can be in between.
A hi flow walbro pump and a stock fpr always results in higher than stock fuel pressure. This isnt a big deal unless you've got an injector o ring thats leaking. Did you take out the fuel injectors recently? If you put them back in w/o lube chances are good you buggered up an o ring.
