Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Wed Oct 11, 2006 4:31 pm
Well, is it constantly misfiring when you go WOT, or is it doing it ocassionally? What is your base timing set at? What fuel pump, regulator, and pressure are you running? Are you sure the plugs are gapped correctly? Have you tried regapping them? Does the engine "misfire" when you are at idle and rev it up to a certain RPM and hold it?
As you know, a misfire can be a multitude of things. I am not meaning that all of the above is your problem, but any one of those can contribute to a misfire. The more information you can give us on top of what you already have will help us to help you.
