cbeaudry wrote:I read on another thread here that a PS flush may solve the problem. I do believe this is related to the steering since the vibration comes through also in the steering wheel and turns returns in the buzzing sound increasing.
When I check the fluid again last night, I noticed tiny air bubbles in there also. Something is obviously screwed up in the line. Hopefully it's just a build-up of gunk. When I last had a check-up on fluids a few months back, they did say they added fluid to the system since it was low. Would it make a huge difference if they didn't put Dexron as recommended?
I'm just throwing that out to know.
The problem was noticeably less today as the weather was much warmer than it has been in a while. Nonetheless, I still battle the steering a bit when taking sharp turns.
I'll get the flush done sometime this week for $50. I'm not a mechanic so I don't want to tinker with the return hose to bleed the system. Hopefully, it will solve the problem.
I would say you probably require a new hose or two, and a full mechanical flush hooked up to the new hoses. You never mention the condition of your fluid. I bet it is not bright pink.
You should do your final fill with M1 ATF, but may flush with regular Mobil ATF. It will cost you at least $100 to hook up to the Sun machine for the flush because of the labor and time involved. Materials and parts are extra, so get them from Joe in advance as you may return what you don't use.
Should have been a BIG RED FLAG for you when the fluid was low. Hopefully the pump itself or valve is not damaged.
