Feel stupid for asking, but...
Slipstream
Car: '94 Sonoma, '90 300zx n/a
I bought a used aftermarket intake and I didn't have the MAF adapter. So, I purchased two that should fit, but I can't seem to find where this sensor should go. One of the adapters has a opening with a rubber plug in it that I believe I need to leave, but can't find anywhere for this part. it's on a '95 240sx SE. Any help is appreciated.
Slipstream
here's the pic from inside the air box.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Looks like an air intake temp sensor, im not sure where youd put it, but i may just put it somewhere cool (keep it out of the engine bay if possible) and see if it makes any difference, i doubt it will.
Slipstream
Do you think I can take the rubber plug out of the MAF adapter and find a way to hold it in place there?
elwesso
2007 BMW M Coupe
I suppose what you could do is cut the rubber plug so that it fits.. Either that, or drill a couple small holes and use a nut/bolt...
Slipstream
I'll give it a try. Thanks for the help.
onosqv
Car: '92 240sx Vert
you can just have it chill outside, it's only for diagnostics.
I thought the ebay adapters would have a slot, but guess it doesn't. My injen intake had an adapter w/ a spot for it.
Slipstream
the adapter I bought was a universal one. I think Spectre, from Pep Boys, so it just had the grommet with the plug. I might try to fab something up if I get a chance. No one seems to have one for sale.
madizmo
Car: 89 nissan 240sx
i took the rubber adaptor ring off of my air filter and cut a little slit big enough for the wire to fit in and put it back on the filter so it is just inside my air filter, that way the air still passes by it, if you get what i'm saying.
