feedback on sc61 turbo
Marahutay
Car: 1991 Nissan 240SX Fastback
http://www.240sxmotoring.com/t3tu50.html
does anyone have any experience with this turbo?
would you reccomend it or reccomend against it?
also, when i get this project underway with the turbo and whatnot, i have ben looking into buying a nistune ecu for my setup. would you also reccomend this or reccomend against it? what are some common problems i might run into that i may prepare for in the future?
any information will be helpfull
thanks nico community!
gaehrings13
Car: Nissan S14
I had one on my 1jz running 21psi and it was great.. It was a .68 rear housing.. 1jz is 2.5 so it shouldn't be that bad on a KA.. It wasn't that laggy on the 1j either. But if you want to make 300hp or something and planning on staying there i would get something smaller.. I think the turbo is good for more than 600hp or around there.
Marahutay
i plan on staying around 270 which i would guess would be around 6-8 psi daily, and have a boost controller to turn it up to 20 psi. i have a built motor so the power will be no problem. i would start hitting the danger zone if i hit anything to far past 600. which i dont plan on doing.
i know i might have a good bit of lag and it may make sense to go with a smaller turbo for my application, but i want to have a bigger turbo so that i do not have to run high boost for daily fun. but also have the option to fully utilize the beast i built : )
did you run 21 psi for a long period of time? about when did you start spooling and when did you have full boost at 21psi? did you ever have any problems with it?
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
You can get it a little cheaper here... http://www.extremepsi.com/store/custome ... 508&page=1
The SC series is old technology for PTE. For $900 you can get a HP6057 which will out spool the SC61 by 400-500rpm and make the same power. With either turbo I would go with the T4 .68ar turbine housing if you can go T4. If your mani is T3 only I would go with the T3 .82ar
Here is the link to what I would get....
http://www.extremepsi.com/store/custome ... 652&page=1
The turbine and exhaust wheel are the exact same size as my holset HX40 PRO billet. Out spool a GT35r and make very close to the same power.
Marahutay
about when do you spool with your sr20?
and how long do you think the hp6057 would last on about 8 psi daily?
and also, what ecu do you guys think i should go with ecu wise?
i was thinking an apexi AFC-neo
kentuckyslider
Marahutay wrote:about when do you spool with your sr20?
Get a rom tune not an AFC. I would just get a Holset HY35 and run 14-15psi with a good rom tune and some 550-720cc injectors.
http://www.rs-enthalpy.com/info.html
This is what the HY35 can do on a stock S14 motor with a good rom tune at 16psi.... you really can't beat it. With some cams and meth injection you will be at the limits of the stock rods.
http://www.ka-t.org/forums/viewtopic.php?t=49206
Marahutay
so i dont have to buy anything computerwise? i have a 91 and i can just go get a rom tune with no ecu addons?
and i have Eagle rods not factory
