Feedback of Tial and JGS Wastegate
tvmendoza
Car: 240sx 95
Hello, i just want to know if anyone is using the jgs wg and what are the impressions of it?? Or if i should go with the Tial. Thanks
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
tvmendoza wrote:Hello, i just want to know if anyone is using the jgs wg and what are the impressions of it?? Or if i should go with the Tial. Thanks
I have the Tial 35mm and its great. Ive ran as low at 6 psi and it was able to bypass the rest of the ex gas with ZERO problems and zero creeps...
Back then Tial was the best on the market along with a few others.. Their still the best in my opinion..!!
wild_maxx
Car: 90 TT pearl yellow z32
i have a 38mm tial wg and its perfect. holds 14psi great.
fiznat
Car: Grown up :(
Tial 38mm works just fine at 20 lbs too
Arrow
Car: 1990 240SX SE - SOLD
2003 Kawasaki Ninja 250R - SOLD
2009 Kawasaki Ninja 650R - corner carver
1998 Pathfinder
A question about the tial wastegates (and others) I noticed that you said that the 35mm held 6psi great (which is something that I would want for my first setup as a economic setting) but what is the max that the 35mm could hold to effectively?
fiznat
Car: Grown up :(
Its not really a question of how much it can hold... more like how quickly it can divert gasses as the boost pressure goes up. The higher you get in boost, the quicker you're going to need to divert the gasses because they are coming out of the exhaust ports at such a high energy. I wouldnt run a 36mm any higher than 10-12 psi, but eh it would probably be fine up to 15 maybe?
Is there a big price difference between 36 and 38? I mean, its only 2 millimeters...
veilside180sx
I have a JGS but haven't ran it yet, hopefully very very soon. I have friends that love theirs though, and Lance runs a great and honest business.
Really I think you'd be happy with either one.
tvmendoza
Car: 240sx 95
So the people voted for the tial?? or should i wait until someone rate the JGS since the price is very similar, also does any sponsor has the tial wastegate??
nissanfanatic
Car: 1992 Nissan 240sx SE
I have the same question Fiz.
I run a Turbonetics Evolution 35mm. Has held whatever I shimmed/sprung for fine. Never even spikes.
Another thing to consider is flow. Turbine size, exhaust restrictions, restrictions in the dump tube from teh wastegate if you are running one, ect. All can influence.
duncan351
Car: S14 KA-T
fiznat wrote:Its not really a question of how much it can hold... more like how quickly it can divert gasses as the boost pressure goes up. The higher you get in boost, the quicker you're going to need to divert the gasses because they are coming out of the exhaust ports at such a high energy. I wouldnt run a 36mm any higher than 10-12 psi, but eh it would probably be fine up to 15 maybe?
That is entirely incorrect. Myself along with slew of others run 35mm wastegates. I've personally run 25psi with absolutely no boost spike.
