I ve put some coilover on my car.
Wich part should i get first beside the strut bar,and a ruca.
wich one are priorities
If you have pictures of those part installed on you cars i would like to see them and have your opinions about it (if you notice a big difference,does it help the car...etc ).
Also where you bought them and where could i get a good deal!!!
If theres some suspension parts i havent put there feel free to post them
Strut Bars
Wich strut bars are the best,and wich one can i get and will just do the trick,
should i take the carbing struts or the second one is ok Is the rear strut bar good (coz it holds only by one bolt),most bars i seen goes in the car on top of the speakers,wich one is betterlook the same as the one on the previous pictures,looks more solid than the other one I heard those are not really good,because they need to be tighthen every once in awhile
Tie bars ???
Is the shortest one a tie bar,and wich one is the better?The blue meagan one or the one in the ebay store do just fine,and whats the name of the one that goes in the top
This one is called rear under brace,where does it goes,is the same one as the picture with the 2 bars Theres also this one called subframe brace???where does it go too
http://cgi.ebay.com/ebaymotors...wItem
Rear under brace kit with 4 mounting points.Someone has a picture of it once its install???
Tunnel braceSome one know where i could get those beside at spl parts
Is this arm the same one as the one in the front on the previous pictures
http://cgi.ebay.com/ebaymotors...32896
Those 3 look the same,is it the same one as the blue one,and if so wich one is the betterI know those 3 are made of aluminium
Type-J Front Lower Under BraceTanabe Drift Spec Front under brace
Nismo power brace
Megan Tension Rod Support Bar
Can i still put this bar if i have a Nismo power braceTanabe makes one too
Ladder bars
Front
Rear
Front Fender Brace
Rear Cross bar
Floor support bar
Do-Luck chassis bars
Bushings
Nismo differential mounting bushings
Aluminum differential bushings
Is aluminum better,i heard it make a lot noise,is it confortable to drive ???Same goes with subframe collars,is it confortable ???
Rear lower control arms
Front lower control arms
Rear stabilizer bar end links
Wich ones are better
Thank you
Modified by S-14 at 1:50 PM 3/29/2007
