BLACKonBLACK98 »
https://forums.nicoclub.com/blackonblack98-u75913.html
Tue Jan 24, 2012 10:33 am
Hoping some of the techy guys are still around. I'm kind of lost on this subject. I have a '90 project that had an ABS issue when I was driving it (looking at speed sensor, everything else was tested/replaced). Now I have an R32 GTR differential and am converting the front suspension to a Frankestein McPherson set up. I am considering swapping the guts of the differential (I am aware that it may be an intensive process) and running S14 ABS front knuckles. What issues might I run into swapping out the front ABS sensor for the S14 sensor? I'm sure there's some compatibility issues but are there viable solutions? Even though the car will be heavily modified I would like to do it with a certain level of quality. The other option is to delete the ABS system altogether, which I'd rather not do.
