FC DATALOGIT VS FC HAKO
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
What are you guys running and i'm not tuning with it I simply want to be able to watch what's going on when i'm at idle and driving around. I like the copilot software but am weary about what to invest into. I have a power fc rb25det. no l or d jetro version just the reg.
Largekid
Car: '96 RB S14 SE, '04 LS6 CTS-V
If you have a Power FC, you have either a L or D jetro verision. If you are MAF, most likely you have the L jetro version. As far as tuning, I had the hand commander with mine, did small things very well. I ended up purchasing the FC Datalogit box to tune the motor completely though. Worked well and I was able to set it up with what parameters I wanted to observe fairly easy. Only thing I didn't like about the datalogit was it was serial only when I bought it, so I had to get a serial to usb adapter, which sometimes wouldn't connect.
USMCgetsome
Thanks for the info bro
