bmadd2402 »
https://forums.nicoclub.com/bmadd2402-u23099.html
Fri Oct 26, 2007 3:47 pm
Your usb converter is listed as a device in the device manager. Go to the control panel>System>device manager>ports, then find your USB to serial converter or whatever it is, and it will list which com port it has reserved for the device (ie com port 4, COM4). then select the proper port in the program you are running. and like it was said above, ensure you have the proper drivers installed.
