Fbu......
USDM_OneVia
Car: Racing
Shimming the wastegate actuator out 2mm for decreased wastegate arm movement and an increase in boost.
Anyone done it? How much does shimming 2mm translate into boost increase wise?
Just throwing out my weekly topic for discussion..... last week it was timing, now it is this.
Talk amongst yourselves......
Joe
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
ok, i understand its like 12psi or something. people on sxoc said to use some thin washers. dont quote me on the boost increment though.
- tim
float_6969
Get a boost gauge. Try it. Let us know! Hehehe. I've got to get my BOV put on this week and then my next install will be some nice ricey autometer boost and AFR gauges in a dual A-pillar pod. I know it's ricey, but I don't wanna mess w/EGT and all I'm worried about is knowing if I'm running lean and a AFR will tell me if I'm doing that or not. After that, S14 turbo and HKS Adjustable actuator. Then the suspension...
NeedCAforS13
Car: CA swapped S13 coupe
^RICER!!!! GET HIM...
:D
Sean
float_6969
*Screams like a little girl!* Man, I'll beat you with my bigaywing and 5 color paint job, and bent wheel, and no interior, and no powersteering!!! I wish I had a hood scoop...
Nismo1182
Car: Z06
How would you go about shimming the wastegate? Taking it apart and such.
boost_boy
Quote »How would you go about shimming the wastegate?[/quote] Get an external wastegate and stop being cheap, guys.:D
NeedCAforS13
external = new manifold doesn't it?
Sean
boost_boy
Quote »external = new manifold doesn't it?[/quote] Not really! If I can do it anyone can.
NeedCAforS13
bigger pic please;) I have no idea whats goin on in that one...
where do you mount it without changing the manifold?
Sean
boost_boy
I'll email you a pic of it.
NeedCAforS13
OK, I found a better picture, but I'm still not sure how you pulled it off? Did you weld it onto the stock manifold? And if so, how well is that holding up? I thought welding to cast manifolds was a ***** of a job?:)
Sean
boost_boy
Exactly! I welded a gooseneck on the manifold closest to where all 4 runners cross each other and directed the gooseneck to a safe area for the wastegate to hang. Had a support rod welded from the gooseneck to the manifold for added safety and anti-cracking measures and that's it. Everything worked fine and the wastegate performed flawlessly keeping my boost regulated at around 14.7psi because the spring I was using. I was basically able to run everyday without operating the boost controller.
USDM_OneVia
Car: Racing
Nismo1182 wrote:How would you go about shimming the wastegate? Taking it apart and such.
The stock wastegate is attached to the compressor housing by 2 10mm bolts. All you do is run a washer between the actuator and the housing. This will push the actuator back by about 2mm. This will "decrease" the rod length on the trap door, there by opening it less which in turn will increase boost.
I do have a boost gauge and may just shim it out for ****s and giggles this weekend (my weekend is wed and thur) and report back my findings. I am running a boost gauge and right now, it hits about 9.5 but it reads a bit low (not zero'd out anymore).
Joe
Nismo1182
Car: Z06
Oh wow, thats it? Id rather do that than keep using my ghetto MBC.
Plus its even better when I pop my hood and the ricers dont see the MBC :D
