Favor request from ka24de 5 speed owners!
numnutzzz
This seems weird but i was wondering if anyone with a stock ka24de 5 speed in their s13 would tell me what MPH they are at when they're in 3k RPM in each gear. i'm asking because my speedo doesn't work right now, i may have forgotten to plug it in during the motor+transmission swap. so this is just for me to have an estimate on how fast im going on the freeway. a cop was behind me today and i totally didn't know how fast i was going. hopefully someone can help me out. thanks
i drive a 92 240sx convertible that just swapped in a ka24de+manual transmission+manual ecu.
slideways92
Car: 1992 nissan 240sx se super hicas
well 3k in 5th is about 70mph thats and 3k in 1st is like 25ish.
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
The speed sensor is on the very top of transmission, if you pop your hood you shoudl be able to see if it's plugged in properly, or even feel if it's plugged in all the way. It will click when it's in.
numnutzzz
its raining pretty hard right now and i just quickly look to see if its connected. i see it and it looks like a clean connection. i tugged it alittle just to do a quick check. MPH and ODO still doesn't work so i need to think of some other possibilities. when the motor was at my friends car, his cluster was working perfectly.
numnutzzz
anyone got the speed reading at 2nd 3rd and 4th gear when engine is at 3k RPM???
thanks slideways92 by the way
slideways92
i made a mistake its like 15mph at 3k in first then second is 25mph at 3k i will do the rest when i get out of school.
MRNA
Car: '99 Maxima, '84 Porsche 944
The brown connector just above the ecu is noted for coming loose and the wires breaking, it has done this on 2 out of 3 of mine and one of my friend's.
onepuff
http://www.f-body.org/gears/
1st 3.3212nd 1.9023rd 1.3084th 1.0005th 0.759Final (Axle Ratio) 4.083
Enter those along with your tire size and redline
Done
numnutzzz
thanks for all the info guys.
slideways92
3rd 40 4th 50 thats it
