benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Sat Feb 19, 2005 2:48 pm
Can I ask why you don't think it's the alternator? Was it recently replaced?
There are a couple quick things you can do to test without removing the alternator to have it bench tested.
First and foremost - Don't drive on that battery. If it isn't being charged you'll drain it and that's just not cool.
Now, to really begin - Start the car and recheck the batt voltage. Then turn on the headlights and check it again and write down the numbers. Second - leave the car running and disconnect the battery completely. If the car dies, it's probably a bad alt. If all is still well, turn on the headlights. If the car dies, it's probably the alt. Last, leave the lights on and hit the brakes. If the car dies, it's probably the alt. If your car is still running then it may be something else, but I'm tending to agree with Chris. If he's right, your car will likely die at some point, thus proving him so.
