fault is pissing me off :(Z32 wipers / ac )
Eli sharp
Car: 89
z32 tt
My 89 z32 tt 2+2 has a intermittent fault that kills my ac and wipers . The screen goes out and I cant use my wipers and ac till it comes back sometimes hours later I've replaced the controll unit and all the fuses . What now ? I really need my wipers ...
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Intermittent electrical problems are usually caused by either a bad ground or corrosion on some connectors.
Eli sharp
Car: 89
z32 tt
It turns out it was a relay in behind the inside fuse box that was plating up ..
What a mission to change out but it fixed the problem :)
Thanks for your advise :)
