fireslave »
https://forums.nicoclub.com/fireslave-u106426.html
Thu Jan 08, 2009 6:52 pm
ok, so I want wide-*** tires because i want good handling, and im trying to figure out how wide i can go on an s13.
completely ignoring the fenders as an obstacle, and trying to keep scrub radius correct.
stock offset is +45mm
if i wanted to use 9.5 inch wheels instead of 6.5 inch, assuming everything else is the same (diameter & tire bulge - im not drifting here)
an offset of +7mm would keep the inner tire in the exact same position relative to the strut, but the scrub radius would be shifted 1.5 inches outward!
lowering the front end of a 240sx will make the camber become more negative because it has struts, which has the effect of decreasing scrub radius, because it causes the steering axis to point more outward.the question is, by how much? some negative camber is a good thing, but i'd think anything more than 1 or 1.5 degrees would be excessive....without massive negative camber, it wont have a huge effect on scrub radius....
which leaves me thinking about 1 thing - increasing the offset to something closer to stock - say +35mm...
this, however, decreases the clearance from the strut to the tire by 28mm compared to stock (as well as the inner fender, but whatever, can always chop holes in that if we want to.... dont know if we woudl need to).Outer fender clearance would be reduced by 48mm compared to stock, but who the hell cares about that?
this got me thinking - are there companies that make coilovers that are designed to increase the clearance, while still maintaining proper damping characteristics?
anyone have any coil-overs that are extra skinny? anyone know any other tricks for changing your scrub radius?
Modified by fireslave at 9:20 PM 1/8/2009
