fastpace's Turbo Install
fastpace
Car: cars of course
Well we started on friday and still have some to do tomorrow. Will post pics and all what was done monday night. Hopefully we can finish most of it up tomorrow.
fiznat
Car: Grown up :(
sweet.
haha maybe this post woulda been more exciting if you actually posted the pics, or information about what you did, or anything besides promises promises promises!!!
haha btw sweet thread.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
fiznat wrote:sweet.
ROFL, BURN
fastpace
Car: cars of course
well i will upload them later, but you can go here to view them:http://www.imagestation.com/album/?id=4286423543
WDRacing
LMFAO...Awsome pics of your typical shade tree parking lot turbo install. Sawzall lying around, parts and pieces everywhere. Looks just like one of my first motor swaps. Best of luck and happy boosting.
WD
bbandit
LOL yea this is at our apt's parking lot.We're a little bit behind though.. its taking longer than what we've originally planned. I hope the car will run tonight (very slim chance). But I am pretty sure it will run tommorrow.
Fastpace's setup is almost exaclty like mine (I posted a thread similar like this, including pictures, 2-3 months ago).except that he will be running some 550cc instead of 370cc(my setup). yea, this car should be able to boost higher than mine.
oh yea if anyone is wondering about how the etd manifold is holding up... it still holds pretty good. the coating chipped a little bit but thats expected.I did 2 major drift events with this ka-t for the past month and everything seems to hold pretty good (except that my WG keeps leaking from the gasket).I got the manifold and the turbine to glow bright red a couple of times too. I'm liking it so far... no melting MC yet so far :)
NX95240
Car: my KA-(sc61)
thanks bandit, for saying something about the ETD mani. i was wondering how it was holding up..
fastpace
Car: cars of course
well we have really hit an obstacle. first it was the egr pipe that took 2 days to get off. Note to others who are doing a ka-t project in the future, take that chit off ahead of time, because it will put an damper into the project. I am going to say that we are 70% done. The thing that is giving us a problem now is the damn motor mounts, they won't buge. I am pretty stong and am usually the one to get really tight bolts off when we work on cars and now I can't get any of the motor mounts off. I tried the whole day, nothing has come of any, well one, but still nothing really. I have no clue on another method of loosening the motor mount nuts. Bbandit is thinking it is because of the curb incident that I was in about 8 months ago cause the bolt to get tighter. I am going to try something else tomorrow, but I was wondering if anyone else have any advice on taking the motor mount bolts off?
On a good note we got the ic piping and half the down pipe welded and they look nice. I will take pics of those after i clean them.
fiznat
Car: Grown up :(
getting those motor mount bolts off: are you using a breaker bar, or at least a home-made one? Try taking the handle off of your floor jack and sliding it over a 1/2" drive... that'll extend the handle about 3 feet and multiply your torque quite a bit. Also spray some PB blaster on that bish.
Structure240sx
bbandit- try using turbonetics fire-ring wastegate gaskets, they are sooo much better. i have 2 extra if you want one
are you gettin the motor mount bolts off to get the oil pan off? try what was mentioned and if not jsut drill into still on the car with some lithium grease on the drill bit and give it a couple oil changes. slos13 did this to his 200k motor.
spoolthis
Try using a dull chisel or a sharp punch on those nuts. That's what I had to resort to. Turned out afterward they weren't damaged enough to prevent my using them upon reassembly. They are notoriously tight and the location doesn't help a great deal.
Cheers
fastpace
Car: cars of course
I will try what yall are suggesting. My goal tomorrow is to get those bastard motor mount bolts off. The sun today just drain the living chit out of me and I took to baths because I felt really nasty. Hopefully it doesn't rain tomorrow. That would really suck, but will try my best to get off those two gay bolts. Oh yeah I up loaded the pics of the piping.
WDRacing
Impact my friend....Although a cheater bar usually works as well.
bruinbear714
fastpace - what i did to get those motor mount nuts off was to extend the wrench with a bigger wrench and use that as a prybar by getting under the car and coming in from the steering column side.
Bbandit - did your manifold have the unwelded joints inside at where the collectors merged? I'm concerned that a piece might flake off and end up screwing up the turbine of the turbo, or they might cause the manifold to crack.
bbandit
The welds didnt penetrate through the inside. However, I havent found any problems with either the maifold or my turbine. maybe not yet...but so far so good, Its been 2 months since I first installed it and Its still holding up pretty good.
fastpace
Car: cars of course
Well we got some stuff done today. We still didn't get the oil pan off, but got very close. Thanks for the ideal guys for loosening the motor mounts. However, it only worked for one side because the other one was kind of stripped. This is what we did, took off the motor mount bolt that we could and also took off the other motor mount from the top. We then lifted the motor by jacking it from the a/c mount. We got the motor pretty high, but the pan still didn't come out. The reason why was because my nismo power brace was in the way of the pan coming off. So today was a good day and kind of a frustating day. Bbandit was saying that it seems that my car doesn't want to go turbo, it keeps on resisting. Oh well, I will show her whos boss. So tomorrow I plan on getting the extra oil pan that i have tapped and jb weld the bung on it and take some stuff from the car to the apartment, because it is just taking up space.
boost infested
Car: cars, chicks, food, and .....
this is what i did to get my oil pan off.
- take the top nut off the driver side mount
- take the lower nut off the pass' side mount
- drop the swaybar by removing the inner bushing brakets.
- jack the engine up by the bell housing.
- remove all bolts from the oil pan plus the 2 brakets from the transmission to the block
- pull the pan down and forward
- remove the 3 bolts on the oil pick up
boost infested
bruinbear714
boost infested wrote:this is what i did to get my oil pan off.
Exactly what I do to remove my oil pan. It seems like you have to jack the engine up a little less on the DE engine than the E engine.
fastpace
Car: cars of course
hey what's up yall. took off some of the front suspension to get the oil pan off tomorrow.
I was wondering what type of material is the oil pan made out of?
spoolthis
Steel.
vuse1
what part of houston are you from? i'd like to check out your kat when its all finished and done.
fastpace
Car: cars of course
I am from the southwest of houston. about ten minutes from the bellaire area. That is no problem. I just got the oil pan back on today and should do quite a bit of it today. Hopefully should be finish today or tomorrow.
huguetpj
Car: 93 KAT Coupe
spoolthis wrote:Steel.
No. Don't have a clue what it is but is not steel, nor aluminium. Just somekind of crappy metal.
2Fast240sx
Car: s13 coupe
fastpace wrote:I am from the southwest of houston. about ten minutes from the bellaire area. That is no problem. I just got the oil pan back on today and should do quite a bit of it today. Hopefully should be finish today or tomorrow.
im looking into going with the kat setup on my car and i would like to see your car.
