fastest street car...
StricNyne
most of us have heard of proejct igor and their monster which is hitting 10's on a stock block and headgasket, but what are other people hitting, i rarely see RB times on the forums, i practically got BPU on my rb25, but my power fc came in last night so i definately wanna put that on the track now and see my times. Is anyone else hitting 10s,11s, or 12s ?
DETurbine
Car: Nissan S13 RB25
They are at 10's now?......last time I checked their goal was a 10, but they only got a 11.1
StricNyne
yeah, i read it somewhere like mid 10's, i wanna pull 11's with my 25
themadscientist
StricNyne wrote:most of us have heard of proejct igor and their monster which is hitting 10's on a stock block and headgasket
some of us haven't how about a link?
tpeezy
Car: totalled
isn't there a skyline that's running at 1350 HP? it's on cardomain.com i believe.
themadscientist
not for very long, catastrophic numbers like that tend make an RB's life measurable in weeks.
tpeezy
Car: totalled
ah i see. i don't see how HP numbers like that affect the motor that much though, as long as you're not redlining it constantly it shouldn't be a problem would it?
themadscientist
it takes big explosions of greater amounts of fuel to make more power. If you pump increasing amounts of pressure into a rigid container what eventually happens?
tpeezy
Car: totalled
ah i see what you're saying. however, HP gets higher as the RPMs get higher, so if you kept your RPMs lower wouldn't your engine be fine?
themadscientist
It's called a 454 big block. small motors don't have the raw size it takes to make big power at leisurely RPMs that's the tradeoff.
DETurbine
If you are wanting fastest street car, it is most likely going to be a domestic...there is a street legal Monza here that is a 7sec car. If you are asking fastest street legal Nissan, I would have to say it is probably the Exvitermini's R33 that runs a 8.2 1/4th. Now if you are asking for the fastest Nissan steet legal car in america, I couldn't tell you.
StricNyne
lemme find that igor link, when i mean street car, i mean a car that sees every day life, but on the weekends u whip up on some hondas, and mustangs lol http://forums.freshalloy.com/u...89925 this is from anothe ri dont know if i can post link but ohh well
mmatl16
Car: 240sx rb20 swap
i havent been to the track yet. it hasnt been open since i had the swap done.
im hoping for 13's though
StricNyne
well my rb25 had a boost leak , i missed a gear and i think i was running 7psi, and i hit 14 flat
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
Does anyone have the vid where Igor is running it? I heard that thing sounds killer crazy.-Alex
240Z TwinTurbo
Car: 2006 EVO IX, 1991 NSX
Igor belongs to my buddy here local in Tallahassee. I am about to help him whip that car back into shape and ready for the track. Car had some ignition issues associated with the tuner and the Haltech. He will swap it with a FAST system and we will retune the thing. Its best pass at 17psi was 11.1@130. He is also swapping in a powerglide so he can launch the piss out of the car. Here are some pics. I rode in the car at 21psi and it was pretty damn fast. BTW, my own personal daily driver 240Z datsun ran (6.9@107/10.6@134) with a crappy 1.8 60ft. That was using an old school 280zxt motor.
tpeezy
Car: totalled
tpeezy
Car: totalled
StricNyne
wow, looks amazing, makes u wonder what internals they r using
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
This is the Stage 2 setup.... who knows what it is now that they are stage 3/stage 4
Bottom end:
Custom 87mm AB-134 (Aluminium-Beryllium hyper-alloy) forged pistons (x6)
Custom ceramic coated tungsten-carbide main crankshaft bearings (x6)
Custom oil cooling system
Custom titanium connecting rods (x6)
GReddy lightened alloy pulley set
GReddy 12 litre enlarged sump
HKS /ATI twin ring fluid-based harmonic balancer
JUN full stroker shaved counter balanced crankshaft
JUN GT spec enlarged radiator
JUN high capacity oil pump
JUN oil sump baffle plates
JUN strengthened connecting rod bolts
JUN strengthened main crankshaft bolts
Nismo N1 uprated water pump
Top end:
Custom camshafts <Undisclosed specifications>
Custom head channel modification and complete proprietary GT cooling system upgrade
Custom oversized Inconnel exhaust valves (x12)
Custom porting and polishing of cylinder head and runners with extensive flow bench profiling
HKS exhaust manifold gaskets (x2)
HKS metal head gasket <Undisclosed specifications>
HKS vernier cam wheels (x2)
JUN brass valve guides (x24)
JUN camshaft bearing set
JUN GT surge tank (inlet plenum) with customised bell mouth entries and tuned runner design
JUN intake gaskets (x3)
JUN oversized intake valves (x12)
JUN strengthened head studs (x14)
JUN tappet shims (x24)
JUN titanium valve retainers (x24)
Mines triple baffled cam cover plate assemblies (x2)
VeilSide 100mm throttle body assembly
tpeezy
Car: totalled
it's not street legal anymore, the guy who owns is too scared to drive it. it's a dedicated drag car now, 3rd fastest 4WD car in the world i believe.
Carl H
ive actualy got a vid of that car doing a dyno pull and it is scary to watch.the car nearly launches off the dyno because it makes so much power.
sparksta
haha ya i have that video. first time i watched it i about cried
klh6686
'90 FB w/ RB20
'92 FB w/ VH45
yeah GTR700
RBTALLY
thanks for the intrest ... I now have my car back in my shop and it will be 3 or 4 weeks befor the new computer and trans are finished... I also put a tomi headgasket , head studs, new main and rod bearings,and fixed the oil pump issue. It should make a little over 600 whl this time.. I will repost the new dyno #'s and times it runs when I get back from the track... the car pissed me off a few mounths ago so I shiped it away and forgot about it for a while. now I'll get back to work on it... And in the 11.1 pas I missed third gear.
accel junky
240Z TwinTurbo wrote:Igor belongs to my buddy here local in Tallahassee. I am about to help him whip that car back into shape and ready for the track. Car had some ignition issues associated with the tuner and the Haltech. He will swap it with a FAST system and we will retune the thing. Its best pass at 17psi was 11.1@130. He is also swapping in a powerglide so he can launch the piss out of the car. Here are some pics. I rode in the car at 21psi and it was pretty damn fast. BTW, my own personal daily driver 240Z datsun ran (6.9@107/10.6@134) with a crappy 1.8 60ft. That was using an old school 280zxt motor.
Wow... thats easily over 600whp on a dynojet. Just curious, was the 2700 weight exact on the dyno? Don't mustang dyno's use load figures (like weight)?
StricNyne
thats HIGHLY impressive, your my hero
tpeezy
Car: totalled
how much money/time have you put into that car?
RBTALLY
so far about 18 mounths and around $15000.00 in parts . this mounth alone it will eat up another 3 grand on the new computer system and 2grand on the new auto trans speed = money and I think it is still to slow. I want to skip the 10's and go straight to the 9's
blk90s13
that car was red ? was it in the MD north vs south drift wars ?
i seen it there in person very impressive workmanship
pros to the owner
