Altiman94 wrote:why's it take a v8 longer to break-in than any other engine?
Has nothing to do with it being a V8 really.
It's the build tolerances of the VH45DE that are the culprit here, as well as the bulletproof nature of the engine.
As you'll recall, mine was recently torn down. All my LH bank cam lobes were mic'ed, as were cam bearings. All were EXACTLY the same as the specs on a set of new ones (0 miles uninstalled) on hand. In addition, the cross-hatching was still evident in the cylinder bores, and there was absolutely no wear within the cylinders whatsoever (supported by a post-reassembly compression test).
This is at 104K miles, BTW. There's no reason to suspect this engine wouldn't go 400K miles or more if maintained as it has been.
