Advanced, and because hot air is less dense is why its slower generally.
When you crank the car up the engine bay, TB, intake runners, and head are all cold. So the air comes in without really being warmed at all prior to entering the combustion chamber. Cooler air is more dense thus has more oxygen, thus allows for more fuel, which creates more power
Upon warming up the engine bay heatsoaks from radiated heat from the cooling sytem, the exhaust sytem and the block itself. Im guessing your intake sucks air in from the engine bay, and this is where it starts.
The hotter the underhood temps the hotter the air one starts with. From there it goes to the throttle body witch has HOT coolant running through it (well not on mine hehe), and it heats the air.
Note if you have a metal intake pipe that isnt thermally wrapped the air is also heated along this intire peice as well, due to heat soak of the metal.
Then you pull air through the runners which heat soak, as aluminum is a great heat conductor, from the underhood temps, head (which heak soaks from combustion), coolant passageway cast onto the side, and so on. Then it gets to pass through the head and over the nicely warmed intake valves...
There is also the egr sucking hot fumes into the mix from 2k - 4k, if your car is still so equipped
Um yeah thats why... If it goes from decent to dog slow then I would be a little concerned. But im not to versed in terms of bootsy so I dont realy no how extreame of a performance hit that is.
