Q45 TB has 2 plugs. Top plug for the Idle Validation and the Lower Plug for the TPS sensor. I need help figuring out which wires from the SR TPS go to the Q45 plugs. Heres a listing.
Q45 Top PlugGreen WireBlack w/ White Stripe WireRed Wire
Q45 Bottom TPS HarnessBlack Wire - GroundWhite Wire - SignalRed Wire - 5 Volt
SR TPSYellowBlueGreenBlack - GroundWhite - SignalRed - 5 Volt
Im pretty sure the wires i have marked on the top are accurate and get spliced together to the Q45 TPS lower harness. I need help with what the Q45 Top Plug wires go to on the SR TPS harness?
