FAST IDLE CAM DELETE?
YELLOW S13
Car: 2009 Pontiac G8 GT
2003 Chevy Tahoe (Old ladys)
2005 Nissan Altima 2.5 (Old ladys)
2006 Nissan Quest SE
1993 Nissan 240sx Coupe (Sold) :(
1994 Infiniti Q45 (Sold) :(
1993 Infiniti G20 (Dead...finally)
Yes I know im going to get alot of s*** for this.... But I'm just curious is it something that is truly needed? I am assuming it is but I'm under the plenum and theTB is off. I have done this on my 240 (yes i know its different) and I looked at FSM a bit and noticed it has the fast idle cam which fills up with coolant and allows car to idle when at cold temps. I'm pretty sure I know the answer just want some more feedback. Thank you
RustyBucket
Car: '94 Infiniti Q45
What would the benefits to removing the fast idle cam be?
I know about the arguments about intake temperatures, but I don't see how it could have any major effect on intake temps.
The drawbacks seem to outweigh any benefits. If you remove it, you'll probably wish you hadn't on a cold morning when you have to keep your foot on the gas to keep the engine alive. Then again, you may not even notice that, given that you live in Arizona.
IMO, it's probably best to leave it as is. I doubt you'd see much benefit from removing the fast idle cam and there are less potential drawbacks if you just leave it alone.
YELLOW S13
Yea your right when I did it on my 240 made only a minute difference. Thank you :)
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Q45tech covered its function thoroughly in some of his previous posts.
Owners must overcome the idea that Nissan engineers add devices for the heck of it.
flyingbrick
its crazy that they couldn't just use the idle up solenoid to control cold idle.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
With the coolant temperature at 174*F or more crank the Auxiliary Air Control valve/Idle Air Control Valve up to 100% and tell me what the RPMs are.
Of course a clean (like new) AAC/IACV will allow more in than a dirty one!
flyingbrick
you tell me what happenes when its all the way open
subtle_driver
Car: 1989 240sx hatchback, 1990 Q45 5-speed, 1973 Datsun 240z, 1987 Starion Turbo, 2003 Subaru wrx, 1995 Infiniti q45 5-speed,
its ok when cold, but when the engine is warm it runs at 1,300 to 1,500 rpms. since the valve is not closing at that temp.
