Fast Idle After Replacing TPS
sdkhalsa
Car: 94 Q45 06 M35
Just replaced the TPS on my 94Q, and now have an idle of about 1500. I believe that the system needs to relearn the closed throttle position. How do you do this, or is there another problem? There do not appeaar to be any intake manifold leaks, and the idle worked fine before changing out the TPS.
Q451990
My understanding is that it is very difficult to properly set the sensor without a Consult. Might be worth having done professionally. Otherwise your best bet is to set using the voltage method (read at the ECU) after a 15-20 minute warm up. The fast idle cam will change the "closed" position if the throttle body is at all cold and throw everything off. And be sure not to mess with any of the little screws on the throttle body or take too much slack out of the throttle cables.
Good luck!
Heath
sdkhalsa
Car: 94 Q45 06 M35
Heath:
Thanks for your response about setting up the TPS. Finally have a bit of time to work on it again, having diverted my energies to putting in upper links on the the rear suspension. Where can I find a description of the "voltage method", having been unable to locate it in the shop manual.
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
PS: For your own sanity don't screw/adjust/playwith with anything on the fast idle cam or you'll be sorry...
I did once....................... once.....
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
A genuine Nissan Consult can do it, and so can a home consult with a laptop..
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You can probe the ECU and do it that way.. as long as its close to .4 volts (meaning .4 volts read at the ECU pins) it will be fine. Youll notice a definite change in the engine as it no longer thinks it is at idle.
sdkhalsa
Car: 94 Q45 06 M35
Where can I find some instructions on probing the ECU? Today disconnected the negative post of the battery for 30 minutes trying to force a reset, but nothing seems to have changed.
elwesso
2007 BMW M Coupe
You can probe it on the TCU (yes trans control unit) on pin 34 and 35
