Check all the 240SX FAQs in one source at 240FAQ.COM
S13 (1989 - 1994)
These are base weights, your car will be heavier than noted here, especially SE model cars.
89-90 Models+ 2.4L SOHC (KA24E)+ 140 hp @ 5,600+ 152 ft.lbs @ 4,400+ 2,684 Lbs.
91-94 Models+ 2.4L DOHC (KA24DE)+ 155 hp @ 5,600+ 160 ft.lbs @ 4,400+ 2,684 Lbs.
S14 (1995 - 1996)+ 2.4L DOHC (KA24DE)+ 155 hp @ 5,600+ 160 ft.lbs @ 4,400+ 2,760 Lbs.
MCS14 (1997 - 1998)+ Front End Changes + Rear Tail Lights Changed+ MC = Minor Change+ Same Motor
Nissan Engine Designation Help
KA-24-D-E (also ... SR20DET)+ KA is the Series + 24 is the displacement ... 2.4L in this case+ D is the valve train layout ... D = DOHC ... no letter = SOHC+ E is the fuel delivery layout ... E = multiport fuel injection
VG33ER - the R designates a superchargerSR20DET - the T designates a single turbo motorVG30DETT - the TT designates a twin-turbo motorZ24i - The i designates a throttle body fuel injected motor
Ex.
KA24E - SOHC 2.4L Fuel InjectedL28 - SOHC 2.8L Carbureted SR16VE - Variable Valve Lift 1.6L Fuel InjectedMA09ERT - SOHC 0.9L Fuel Injected "Super" or Racing TurboSR18Di - DOHC 1.8L TBFI
Japanese Motors
SR20DETs
"Red-Top" + S13 Motor+ 205 hp @ 6,000+ 203 ft.lbs @ 4,000+ T25 Turbo+ Called a Red-Top because of its deep red valve cover
"Black Top (S13)"+ 180SX Motor+ 205 hp @ 6,000+ 203 ft.lbs @ 4,000+ T25 Turbo+ Same thing as a Red-Top but newer and has a black valve cover
"Notch Top / S14 SR / Black Top"+ S14 Motor+ T28 Ball Bearing Turbo+ 220 hp @ 6,000+ 203 ft.lbs @ 4,800+ Called a notch top b/c of the variable valve timing bulge on the valve cover, valve cover is also black
"S15 Motor"+ S15 Motor+ T28 Ball Bearing Turbo + 250 hp @ 6,000+ 6-Speed transmission
"GTi-R Motor"+ Sunny GTi-R Motor+ Garret T28 + 227 hp + Individual Throttle Bodies+ AWD layout... meaning its FWD when swapped.
CA18DET
"CA"+ 89-90 S13 Silvia, 89-90 180SX, 89-94 200SX+ 170 hp + T25 Turbo (Smaller compressor a/r than the SR turbo) + "RB" Style Valve Cover ( very easy to distinguish a CA )
Many names of the S13/14/15s in the world- 200SX - Silvia - 240SX
