fan upgrades
z.Leinbach
Car: 1990 Nissan 300ZX NA T-top
well couple weeks a go my water pump broke and destroyed the fan shroud, so for the time being im running shroudless, bad idea i know, but im looking to possibly upgrade the cooling system. input and and suggestions are awesome.! except park it, ( its a daily)
nissanfreak12
Car: 92 300zx 2+2 TT
Electric fans;
MARK VIII electric fans
Taurus SHO fans
I think the MAxima fans are a direct fit for NA radiators
I have ran shroudless in AZ, not in the middle of the summer mind you, had no issues on NA or TT. NA was stock and TT had Aluminum 2 row and stock NA fan clutch. I never had any cooling issues at all. Even when I drove it from AZ to CO.
z.Leinbach
Well when i do my upgrade, i plan on getting a light weight crankpulley, nismo thermo, newer oem rad for weight reasons, but i was on concept z and saw that they tyc depo fans that show they fit up to the stock rad. anyone ever add these on with good results?? also noticed the other day that the fan in front of my ac condencer was seized up (explains why my ac doesnt work now) can that be replaced without removing the bumper? also any advise on which products to get as far as fans go? id like to very much be able to drive this across country and back, while maintaining great temps, ultimate reliablility (for the car in general)
budget300zx
Car: 90 300zx NA
1989-1994 maxima fan is what Ive seen offered on concept z
https://conceptzperformance.com/tyc-dep ... p_9565.php
ebay link
http://www.ebay.com/itm/New-Dual-Radiat ... ~l&vxp=mtr
both fans have 2 speeds, so you may want to consider what type of fan control you will be using. N/A models only have single speed control.
z.Leinbach
alright awesome that's the one I was looking at actually. that will mount to the stock rad right?
z.Leinbach
will anything higher then 94 mount up as well???
budget300zx
Car: 90 300zx NA
I do not know for sure so i cant comment. i have debated doing the fan upgrade but it keeps getting bumped off my list.
Ive heard the 89-94 will bolt up to a NA radiator just fine, and i dont think coz would sell something that doesn't fit right either.
Hopefully someone else can chime in.
z.Leinbach
i also looked at the 96 fan assembly on line and it apears to look the same
budget300zx
Car: 90 300zx NA
The 96 fan will not fit. The bottom does not mount the same way as 89-94
z.Leinbach
oh ok. I got a shroud for the clutch fan, soo ima stay with that and do a underdrive kit, or maybe the super light weight pulley, but I need to recharge my AC so it actually works and blows cold.. again
DCaff300ZX
Car: .
1993 CRP TT- Modified
z.Leinbach wrote:oh ok. I got a shroud for the clutch fan, soo ima stay with that and do a underdrive kit, or maybe the super light weight pulley, but I need to recharge my AC so it actually works and blows cold.. again
Just an FYI regarding the AC recharge, you will have the old style refrigerant that cannot be recharged, so you will have to upgrade to new refrigerant which also requires some work, and a lot more $ than a simple recharge. For this reason I left mine uncharged after my accident- not worth a lot of money for a day or two of AC per year.
z.Leinbach
I have a good hook up for it. But here on the east side of Washington it's around 85-105 all of the summer months
DCaff300ZX
Car: .
z.Leinbach wrote:I have a good hook up for it. But here on the east side of Washington it's around 85-105 all of the summer months
Really...maybe I'll have to come your way one of these days for that job as well!
z.Leinbach
Lmao, right.. even at the dealership I work at its around 200, for the retrofit, but that's even high from what I hear. My friends dad does alot of work.
