Fan stayes on full blast... any options?
Skapunk4everr
Car: 95' j30
Hello all,
For about a month now, the Cooling fan runs at full blast where ever i go. I have done a search and I did not find any information on this. I seem to have misplaced my service manual so any help would be greatly appreciated.
thanks,
Andy
Modified by Skapunk4everr at 8:33 PM 8/27/2008
yodawill2000
Car: 94 Infiniti J30
Sounds like the resistor pack is blown.Ive had the same thing happen in other cars.Surely someone will chime in and know where its located on the J.Normally its behind the glove box where the blower is.When its blown the full 12 volts goes through instead of resistors stepping it down for the other three speeds.
The technical name is Darlington resistor. actually transistors.
Modified by yodawill2000 at 1:11 PM 8/27/2008
Skapunk4everr
Car: 95' j30
even though the J30 fan is belt driven its till controlled by the resistors? Ill check it out.
-- also the fan seems to only rev up with the engine, almost like it spins faster with increasing RPM. could this be because the belt is too tight(doubt it though)?
Modified by Skapunk4everr at 10:51 PM 8/27/2008
coolyun_98
Car: 1993 J30 11,7000kM
you will need a new fan cluth. The cluth is silicon coupled wihch will make the fan turn faster when temp increases. Sounds like your fan is always coupled.
I recommend OEM fan cluth as I have heard many bad experience about aftermarket units.
yodawill2000
My bad ..I thought you were talking about your AC Blower fan.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
yodawill2000 wrote:My bad ..I thought you were talking about your AC Blower fan.
Same here, along with thinking that it's probably very hot in Scottsdale, AZ all of the time this time of year. Once? Great? minds think alike?
Things are a lot noisier when the engine first starts and before the fan clutch disengages.
Modified by GerryO at 12:02 PM 8/28/2008
Skapunk4everr
Car: 95' j30
Yeah i figured it was the fan clutch. I just dug up my FSM, and I will get to work.
