The computer I'm running is a PC my uncle built for me. As it stands, it has multiple fans that run full tilt any time the computer is on. Since I'm not much on gaming and whatnot, it doesn't have all the fancy graphics cards and stuff. Not a bad computer, just enough to run AutoCAD.
Basically, my problem is that my computer is in my bedroom with me, and the fans are loud. Additionally, they suck in all the dust in the room and create one hell of a draft that freezes me during the winter at my desk.
I want to control the fan speed in a manner similar to the way my old Compaq was. The fans would turn off when the computer was idle, turn on at a slow speed for most use, and go full tilt when you were really using it.
I would think that this would be thermostat or thermocouple based. After doing some research, I thought about using something like this:
http://www.newegg.com/Product/...95011
Another thought was to daisy chain the fans and use a single rheostat to control speed. Either way, it leaves me with the same problem: temperature control.
As best I figure, if I keep the temperature inside the case below 50* C, I should be fine. I know there are fan controllers out there that have temperature sensors integrated, but I haven't found any that are in my price range ($20 or less).
Given the fact I don't use the computer for much more than puttering around the internet and IM, could I get by with a rheostat control of the the fans and no temperature monitoring, and just crank the fans up if I'm going to really be pushing the computer?
I had considered the other alternative low cost option of adding a mercury switch style thermostat with an override relay to kick the fans on full tilt if the case temperature became excessive, but I wasn't sure if it would be necessary.
If any of you are familiar with this subject and can shed some light on the matter, I'd appreciate it.
