Good thinking, i should have thought of that, that would be my guess to. but do they really do that much? like is it worth rubbing all the skin off my knuckles against the radiator for?maxnix wrote:So the line of reasoning is Infiniti just had these lying around the factory and got rid of them by installing them on the VH41DE?
Also, are you installing the fan and the fan clutch as an assembly onto the front of the engine? Or are you installing the fan onto the fan clutch already assembled onto the engine. Removing the fan and clutch together is easier, four bolts that are easily seen.jarred15801 wrote:Okay thank you ill try that out
