theboy419 »
https://forums.nicoclub.com/theboy419-u29066.html
Wed Mar 22, 2006 5:33 pm
i have a bit of an odd question... last spring, my plastic intake cracked and was pulling in air past the sensor, causing the car to idle very low and generally just stall. i remedied this with an injen aluminum intake because the source i got it from was affordable enough to seem more worth it than a replacement plastic piece. anyway, that aside, now with the cone filter on this intake, all is well except that the fan shroud which the intake piping runs across, is slowly breaking at the mounts on top of the radiator. i assume this is do to turbulence of the cone filter moving about and shifting the piping back and forth over the shroud... anyway, i was just wondering if anyone had any major recommendations for how to hold my intake better in place, if i shoudl just remove the fan shroud, etc... any feedback would be greatly appreciated thanks!
