driftin_sr20det »
https://forums.nicoclub.com/driftin-sr20det-u33183.html
Mon Sep 15, 2008 5:10 pm
I've been doing a DOHC swap into my buddy's '90 coupe, and we've run into this issue with the electric fans I installed. We used 2-12" fans with a 40 amp relay. I first ran it from the fuel pump fuse to get a signal for the relay, when the fans were plugged in the motor would chug and die. Unplug the fans and it would idle perfect at 800. So I switched the signal wire over to the ACC from the fuse box on the driver side of the car, thinking that it was maybe pulling too much juice from the fuel pump circuit and causing it to run crappy. Well that also caused the same effect. So now I'm stuck wondering if its the battery, alternator, or something else. I searched and only found 3 situations close to mine and none of them had any difinative answer's. So any suggestions would be great.
