214kka-et240sx wrote:that is stupid. you dont need a fan to your fmic. your are not boosting at idle.you will get enought air once you are going .
There's already people who do this, and for good reason.
Adding a fmic makes it harder for air to go from outside -> engine bay. It's another obstacle in the path.
By having a fan between the fmic & radiator, you can effectively use it as a pull fan for fmic & a push fan for radiator. No, this won't help under boost conditions much, but will totally help for most of daily driving, which is just as big of a concern for most of us.
This should definitely help during idle. Of course, you will need good shroud construction so it pulls air through instead of around.
Once you hit a certain speed, fans don't matter much anymore anyway - that's y some of us have that handy dandy "highway speed - turn off fan" button.
I guess this can be considered an alternative to the v-mount setups.
The only way to know for sure how effective this is is to run tests & get some temperature readings, but I'm sure most of us are too lazy to do that, I know I am.
