elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Oct 15, 2005 4:29 pm
This was just discussed in another thread. Unless the fan is severely cracked where it seems to be flimsy, youll notice that the fan while its still cracked is still fairly sturdy and wont fall apart. if this is the case, then you can probably get by with replacing it.
is it worth it?? Thats your call.
Replacing the fan only takes a few minutes, its held in by 4 10mm nuts on the flange of the water pump. Just take those out and the fan and clutch comes right out. Swap out the old clutch into the new fan and your in business....
20 min job, TOPS.
