fan conversion and misc.
91-q45
Car: 1991 infiniti Q45
ok, a couple questions, first off, i drive a 91 q, ui just purchased it and its not in bad shape, i hjust want to do some things to it to give it a little extra power(not saying that it doesnt have enough, im just never satisfied with what i have. lol)-has anybody done an electric fan conversion on their q?-does anybody make a fiberglass or carbon fiber hood for it(the hood weighs a ton)?-i read that most 300zx suspension parts are transferable to the q, but i was unclear on wether or not the springs are?
thanks for any feedbackryan
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
1. in the case of the Q, doing an electric fan conversion usually isnt worth it because a fan that big would just draw a ton of power from the alternator.
2. no. The stock Q hood doesnt really weight that much IMO.
3. The suspension links are, the springs and shocks are not but you might be able to put Z coilovers on with some basic modifications... It has been done.
Welcome to NICO. where in IN are you?
qship96
Car: 1996 Infiniti Q45
If you want to do"some things" to it,or even continue to drive it at all-Make sure the chain guides have been updated,or it will just be a 4000 pound lump in the driveway!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
The best thing you can do for performance after you have restored it to as new OEM condition is add the rear a model sway bar, Jeff's FST bar, tha ATF suxiliary cooler and the NICO ECU. And of course new top rated tires as you can buy in the appropriate wheel size will increase handling and braking performance the most, providing you observe the initial caveat above.
91-q45
-what if i put two smaller electric fans?-what does IMO mean?-who did the z car coils, and what mods does it need?jw-im pretty sure by now it has to have had the tensioners because it has 190,000 miles so im guessing it has been done already if its still running lol
o n im in northern indiana, bout 20 minutes from notre dame university.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
91-q45 wrote:im pretty sure by now it has to have had the tensioners because it has 190,000 miles so im guessing it has been done already if its still running.
Really bad guess. Frequent religious oil changes can postpone failure, but never eliminate it.
You need to do some reading in the articles and previous posts. Including Wes' answer above.
Modified by maxnix at 11:52 AM 11/14/2007
elwesso
2007 BMW M Coupe
I agree, dont assume the guides have been done. Many times you can get just really lucky.
BTW, im in Angola (intersection of the toll road and I69). if you need Q help hit me up.
gammer_ghn
Welcome = ] why dont you go carfax the car and pull all the info from your dealer and start from there!
NOR*CAL 916
Car: 1994 infiniti q45
i have 2000 nissan altima fans in my 1994 Q45 powered by the HKS fan controller, it DOES make a difference in the q its alot more rev happy
