Fan controller wiring
Mouse6933
like the idiot i am i forgot to label my wiring, for my can controller. i checked out otther ones, like from frsport.com and there is simple , labeled and esy mines got some letters on it and i dont understand can any please help[
ok from left to right
there is a C above a B, M, G, +, M+ above M-
and the wires i have is a ground, 2 into 1 from power to fans, 2 into 1 for ground for fans, 1 into 2 power from battery, and another wire that i have no idea where it go;s too. im confussed as hell,
http://www.cardomain.com/ride/2314999/2
bruinbear714
Mouse6933 wrote:like the idiot i am i forgot to label my wiring, for my can controller. i checked out otther ones, like from frsport.com and there is simple , labeled and esy mines got some letters on it and i dont understand can any please help[
Not sure what those letters mean, but it seems like you're referring to the flexalite unit? I had that unit on my car and after 6 months it failed. Your best bet would be to see an example of the unit installed on the car or check out the instructions.
Now I am using the DiF fan controller and it was extremely easy to install - +12V, fan 1 and 2 output, and the ground wires (unit & fans), and the coolant temp wires. Because it uses the stock sensor, there's no probes to insert through radiator / coolant hoses and the readings are a lot more accurate.
Mouse6933
yea i wish i had the instructions the swap was done for me about a year ago, and since then ive been going back and finding things they did half ***, like pretty much all my wiring. guess thats what i get for paying for someone to do it. yea i saw the dif controller, just figured id see if any one couild help me out , but i guess ill just buy thaty one. i guess i just need to find the stock sensor, beacause this ones got the probe in my radiator...
thanks again for the help
myles
