Fan Controller help (not DiF)
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
http://shop.advanceautoparts.c...A____
i want to get rid of the switches in my car, and i've been running my fan off one for awhile and noticed it gets fairly warm sometimes... i found this, and am probably going to get it and install it tomorrow, but had a few questions.
all i have to do is mount the sensors somewhere on the radiator, mount the box, and wire it to battery and the fan and its good to go? no seperate relay or anything? thanks everyone.
seperate question, my fan pulls ALOT of current, probably no way to make it draw less, is there?
DRIFTKNIGHT_240
Car: 240sx Zenki s14 [going sideways]
just remember to wire the fans to the fuel pump fuse or relay ..>>.good luck ..these are mines...!!
Modified by DRIFTKNIGHT_240 at 11:43 PM 5/30/2009
Modified by DRIFTKNIGHT_240 at 11:44 PM 5/30/2009
Modified by DRIFTKNIGHT_240 at 11:45 PM 5/30/2009
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
recommend running a relay
sjbsuperman1425
CA18DET
so basically wire it like Darknight did, using the wiring diagram for the relay? Thanks alot.
and sensor should be mounted on the engine bay side of radiator correct?
sjbsuperman1425
CA18DET
ok, i just got done installing it and it works great! i didn't play around with the adjustment that much yet, but with the stock gauge needle at half, i have it turned up just a little bit. but it turns on/off so im happy lol Thanks alot guys.
NO MORE SWITCHES IN MY CAR!! now i need a new radio bezel without holes so it looks clean
sjbsuperman1425
CA18DET
ok, so i've been running it for a day, and the fan turns on and off good yesterday. but today i noticed after i turned my car off, the fan stayed on a bit (5-10 sec.)? any reason why?
mRodiek
Car: Stock Hatch
The engine is still hot after you turn it off so its still trying to cool it down, most cars have a warning under the hood "keep hands clear of fans, may still be moving after car is off".
Warped161
Car: 90 s13 the never ending project
If you don't want the fans to run after you shut off your car you would have to wire the controller to your ignition. otherwise its fine.
sjbsuperman1425
CA18DET
so basically just take the wire coming off the battery and tap it into something with 12v switched? the fans wont stay on that long after shutting off would they?
sloweighty
Car: sileighty
sjbsuperman1425 wrote:ok, so i've been running it for a day, and the fan turns on and off good yesterday. but today i noticed after i turned my car off, the fan stayed on a bit (5-10 sec.)? any reason why?
i wouldnt worry about that, just leave it like it is........and dont worry about your battery dying if it runs for 5-10 secs cause i had my fans run for almost an hour and everything was still fine
Hoffman5982
Car: '95 sr20det 240sx
is that fan control labled 1 2 and C? which one are you connecting to the relay? I have a flex-a-lite controller and I dont know which to hook to the relay,unless Im supposed to send both of the prongs to it. Also, the four wires on the plug are solid black, white with black stripe,white with blue stripe,and white with red stripe.could you tell me which are positive and which are negatives?
Hoffman5982
I thought this forum was for helping people? Ive asked this question numerous times and I have gotten nothing. I wired it up without the relay and now the fan is on when the car is off but when I turn it on it shuts off.why?
Cone Junky
Car: S13 fastback
BMW e46 328i
Hoffman5982 wrote:I thought this forum was for helping people? Ive asked this question numerous times and I have gotten nothing. I wired it up without the relay and now the fan is on when the car is off but when I turn it on it shuts off.why?
So you're taking a stab at our efforts to help you and then asking for help?
Sounds like you have it wired completely wrong, especially since you don't have it on a relay.Why don't you pay attention to the wiring schematic that somebody already posted and use that for a reference?
Hoffman5982
well I had it on a relay but when I asked which prong of the controller I need to cconnect to the relay noone answered me, so don't tell me to pay attention. Ive been paying as much attention to the stupid pictures and little paragraph about nothing as I possibly could
That temp probe is set up WRONG.
And you're running a thermostatically-controlled e-fan. Quit being a jackass and remember, you're using another component that's NOT included in that diagram.
sjbsuperman1425
CA18DET
how is the probe set up wrong? i used mine like that all last year and it worked fine?
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
all i have to say... if you have to ask...
then SEARCH more. find concrete info. its not hard. the internet is a big place FULL of info.
sjbsuperman1425
CA18DET
mrgreeneyes wrote:all i have to say... if you have to ask...
what are you talking abt? Im asking why he thinks thats mounted incorrectly. I had mine the same exact way and had no problems.
