-->> I suggest that you first try starting the blower by giving it a push and see if it goes. If so, bad blower, cheap/easy fix. You'll have to pull it out to do that, but IIRC it is only 3 screws.
I replaced my control amp this winter (2001 QX4) -- had to get the part from a dealer, since I needed to get to snow country, and didn't want to be in bad conditions with no defogger. Worked for 2 days.
Turned out that it was the blower, not the control amplifier. Something was open (brushes?) when the fan would stop in certain positions. If I would start it by hand, it would keep going. Depending on exactly where it stopped rotating when I turned it off, it might or might not start again. I could also measure approximately 200 ohms on the motor winding at certain positions of the blower, whereas it should be more like 1 ohm.
I tried disassembling the blower (hopeless) to see whether I could see what went bad. Damaged the blower, but was stupid enough to hook it up to the controller (control amp) again, which burned out my new control amp (sparks, popping).
Got a new blower, put back in my original control amp (which was never bad after all), and everything is fine.
Blower:
http://www.amazon.com/TYC-700044-Nissan ... detailpage
If you want to bother with it, there is a write-up on how to repair your own control amp, which you can do for maybe $15 in parts or less.
DIY repair of control amp:
http://www.nicoclub.com/archives/fix-th ... issan.html
I got the parts, but haven't bothered to fix the one I damaged, since the original OEM works.
Control amp:
http://www.amazon.com/dp/B00BFE5NN4/ref ... YX8YU05QZW
There may be some change in part number from year to year, so always check.
