so here is the story.... replaced fan clutch and water pump when i did the 120k maintenance last summer. both are aftermarket. a month ago, the Z started making noise and i felt vibration on the shift knob. it was coming from the fan clutch/ water pump. the fan clutch was loose and that wiggling messed up the water pump. so i replaced them again with the same aftermarket parts since they come with lifetime warranty. this week, i am having the same problem!
So what factors could be causing this? my fan has cracks along the base part where it screws on to the clutch. doesnt seem major but could that be causing the issue? could it be that the water pump belt is on too tight and causing too much tension on the water pump thus making it loose?
I NEED HELP!
Once again, Thanks!
JONA
