Pirate_Freder »
https://forums.nicoclub.com/pirate-freder-u64592.html
Wed Apr 30, 2008 1:17 pm
actually i believe that mechanic lied to you or is flat out wrong. i have heard a timing chain that is insanely loud at start-up(like the screw driver analogy you mentioned) and i can't imagine why a fan clutch would make a noise like that. since the chain tensioners are hydraulic you could be low on oil, have low oil pressure(rebuild the oil pump for dual cam or get a new one for single cam, or maybe oil pan gaket or pump pick-up), or just a bad tensioner.
try putting your ear close to the valve cover at the very front of the engine(of course being wary rotating objects lol) and see if the sound is coming from there. ACTUALLY, just go ahead and take off your valve cover and front cover to see if one of your chain guides has snapped(see pic below). the pic shows the top guide which snapped on my ka24de but there also one to the right and down on the side. if either of these have snapped then remove the broken one(s) completely. also check to see if there is where one your valve cover or front cover from the chain rubbing if one or both of the guides have snapped. once you have all tension issues resolved remove those two guides if they aren't already gone(nissan later removed them from the engine design since they are not much more than a hazard, i just think it's better to hit those while your chain is loose rather than letting it flap wildly).
EDIT: if your are around 100,000 miles or more time to rebuild your whole timing chain system with at least new guides, tensioners, and chains and maybe your oil pump too.
