Well, it's not doing either one of those-so thats good.qship96 wrote:Not sure by hand, but when mine failed, it failed in locked position, causing a ton of noise due to the amount of air it was moving-the fan was literally spinning at engine speed...above 2000 rpm,it sounded like a jet.They can also fail in unlocked mode, clutch just freewheels, fan wont spin fast enough to cool motor at idle or low speeds
