ca18detgabby wrote:People run the ET w/p because it lines up right WITH the DET clutch fan as apposed to the DE wp....... should have no problem at al.
why not try it. clutch fans are not exactly scientific items. I have two 12 electric fans if you need them, but that clutch fan should work fine.
PS you can run a FWD WP so long as you are not using a clutch fan. that is the only issue with the FWD w/p
I went through basically the same thought process as this and coughed up $30 for a new CA18ET fan clutch at rockauto.com (gotta love the "wholesaler closeout" pricing, and I got the last one! ahaha)
I have a Taurus fan + temp switch + wiring sitting in the garage that I ran for about 7 months. It worked fine, even overcooled the engine at times. I just get bored easily and wanted to try the clutch fan since it looks cooler
We'll see if that ET fan clutch works, fingers are crossed.
