captainluigi wrote:ya mon, replace the blades. easy diy,er. expect a skinned knukc or 2. pop of or out those plstkj buttns & remove plstk cvrs thn use 1/4 dr. w/10mm. wrk the bld arnd nd rmv, goes back dblez mon. hld rtcht at hd gvs bout 12# torq. buy da new plstic buttns eny auto store. clear runin mon. no wurries. stay irie!
Allow me to translate into english:
Yeah, replace the blades. Its an easy DIY projecet, but expect a skinned knuckle or two. Remove the plastic screw type clips and remove the plastic cover over the radiator. Then remove the fan from the water pump pulley with a 1/4 inch drive 10mm socket. Work the blade around and remove. The nuts need to be on there slightly tight (about 12lbs of torque) but not really tight...
