Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Thu Mar 08, 2007 6:20 pm
Your engine does NOT have an automatic tensioner. As a belt ages, it will slightly stretch. To compensate for this you will have to apply a little more tension to the tensioner, or replace the drive belts. To eliminate your belt squealing and if the belts aren't cracked, you can simply tighten the belt tensioners.
You have two tensioners, both can be accessed from below your engine bay with the splash shield removed. On your "alternator belt", you will see one tensioner/pulley. Loosen, do not remove, but loosen the 14mm nut holding the tensioner puley on. Then take an extension with a 12mm socket and tighten the tensioner that is located under the pulley. You only need to tighten it slightly. Once the desired tension is reached, simply tighten the tensioner pulley nut. Do the same for the "A/C Belt" and tensioner assembly.
And since you are going about this, you may just want to simply replace the belts, unless they were just recently replaced.
