onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Mon Jan 31, 2005 9:25 pm
Yea, the fan is always on. However, when you hit the highway it goes into a free-spin like bcar240 says. It will be ok.
The performance advantages between the mechanical & electrical fan are "controversial," you can look at the billion threads we have on nico for that.
Advantages of the electrical fan for sure: more working space, easier to get access to things like upper radiator hose, coolant temp sensor, pulleys & belts, etc.
Disadvantage: make sure you ground that **** & set up the relays securely, cuz if anything loses its ground, no more spinning fan -> overheat. Happened to me a few days ago bcs of my stupid *** grounding it to a bolt that snapped that day . Also, if you run underdrive pulley w/ sound system & headlights on, raise the idle - my car can barely handle the stuff - I deal w/ it tho, hehe.
