emperor_lunchbox wrote:I dont mean to sound defeatist or anyting, but it would be impossible for me to find a hose off or a hole in a gasket. Is there a typical hose that causes this or a typical gasket that could attribute to this?Thanks for your suggestion, I will have another go with those lines.
To check the intake system for a vacuum leak, attach a vacuum gauge to a full vacuum source. A good place to connect to is the charcoal canister. There should be three hoses connecting the carbon canister. Two of the hoses go to a purge valve that's built into the canister. The second larger hose off the purge valve should be your vacuum line. With the motor fully warmed up, the reading at idle should be 18 - 20 InHg. At 3,000 RPM, it should be 21 InHg.
If readings are under 18 InHg, check the intake manifold nuts to make sure they are tight. Also check the intake plenum bellows at the throttle valve and at the MAF for cracks or loose clamps.
The idle hunting can also be caused by the following:1 - Sticking EGR valve.2 - TPS harness connector pins. Look at the pins and see if there's oxidation on them. If so, clean them with fine steel wool then lightly coat them with 'dielectric lubricant' which you can get at most autoparts stores.3 - Dirty air filter.
