False car alarm activation?
Mrpete
430am it wakes me up. (impressive)
Investigate and see no harm. Reset and come back in. 3-5 mins later off again. Reset and back in for one more false alarm. I then open and closed the door and locked it with the key itself. So far 30 minutes of peace.
Suggestions on what can do all the above?
Sleepless in Cincinnati
Pete
Q451990
:welcome: to NICO!
I know you were sleep deprived when you wrote this :D
What model and year of car are we talking about? Is this the factory alarm that's going off, or an aftermarket one that was installed?
Heath
Mrpete
M35X , '07, factory alarm
Q451990
I looked through a database of the TSBs (technical service bulletins) for your car, and don't see anything. I'm going to move this thread to the M forum, because I think you'll get a better response there.
Good luck!
Heath
EniGmA1987
Car: '06 Infiniti M35 Sport
Its possible your trunk is causing the alarm to go off. I have had a lot of flase alarms too, usually at all hours of the early morning. Usually when it is cold. I found if I open the trunk and close it hard then the problem goes away for a while.
Every once in a while I will be driving and my trunk open warning will come on after this has happened too. When I havent opened the trunk in quite a while and had no problems before.
