false/broken temp gauge + coolant drops
silkk
Car: 94 B13
89 S13
07 S2000
it's a 89 with stock KAe. when i start the car to let it idle, the temp gauge goes to the middle and after 10-20 minutes of driving, it would go to hot. now when i drive around, its always on cold.
i'm thinking its a broken sender or the gauge.
a coupe of days ago i noticed my car was dripping coolant, but the weird thing is its not from the radiator but its behind the oil pan. i don't know why and how its dripping. i check the resevoir and i don't notice a difference in volume.
and i don't know if its normal or not but my car warms up really fast.. after 5-10 minutes of driving, my radiator cap is really hot. :(
:help
silkk
Car: 94 B13
89 S13
07 S2000
here are pictures
is the dust boot suppose to be like that??
navysnail
WOAH, your loosing alot of coolant, the resavour is not the place to check, open the radiator when its cold, not hot, youll burn your self
look ontop of the engine were the intake manifold is and by the hoses, that needs to be fixed asap
and those rack boots need to be replaced too
silkk
Car: 94 B13
89 S13
07 S2000
what thing on top of the manifold?
i don't see how the coolant is getting there..
and this just started recently and i haven't been driving it, maybe once every 2 days for 10 minutes :(
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
how about check the gasket between the thermostat and thermostat housing or the water pump, if not check your hoses as well
navysnail
with a leak the size of that, it shouldnt be too hard to finid
your temp gauge is probobly wierd because it may be in an air bubble
the dust boot, if not replaced, will allow dirt into the seals and ruin the rack
silkk
Car: 94 B13
89 S13
07 S2000
oh man this sucks
if only i had a job :(
i'll try and find out what's wrong with it and get it fixed asap
NISTECH
dont drive it! When the gauge reads cold and you have an obvious leak that means coolant is not contacting the sensor. Your ecm has no idea how hot the engine is because its sensor is likely in an air pockets as well. It thinks the engine is cold as well and it will do what it needs to to heat the car up to operating temp but in accuality it will heat it up to a engine damaging overheat condition and not even know it. The reason the fluid stays in your resivor is this. When a car heats up it expands the metal and the fluid , that expansion pushes fluid into the resivor,once you shut the car off it goes into a cool down process during that time the expansion process is reversed putting the system into a vaccum which pulls the fluid back into the engine. Now that process wont work if there is a hole somewhere else in the system. It will find it easier to push the fluid through the hole rather then into a tank full of fluid. On the cool down side it will be much easier to pull air in then fluid so when the vaccum occurs it will draw in the air through the hole rather then the fluid in your bottle.
silkk
Car: 94 B13
89 S13
07 S2000
where do you think the leak is?
its probably gonna be some place thats hella hard to get to :(
NISTECH
start checking the heater hoses under the intake. thats the best place to start looking. you could also loan a coolant pressure tester from auto zone and pressurize the system after you fill it and see where the leak is coming from.
180fan
Car: 89 fastback
holy smokes! How about taking pics of the water pump, thermo housing, the front portion of your intake manifold, from the top and bottom, and also the heater hose area?
